chiped ecu?
Old Oct 17, 2005 | 06:59 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
Default chiped ecu?
do you guys know anything about this? it seems like a good deal, but usually good deals mean cheap parts. so what do you guys think about this whole thing? http://phearable.net/chippedecus.html. thanks for the help guys.
Old Oct 17, 2005 | 07:14 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Search on here or ht to see how reputable they are. Chipped ecus are good if you want to keep it simple.
Old Oct 17, 2005 | 08:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to take into account the cost tuning of one of those chips for your setup.
If you don't have the mods, you don't need it.
Old Oct 18, 2005 | 03:54 AM
Jay_Sensing's Avatar
Jay_Sensing
throttle in a bottle
The prices seem a bit high but that may be because we have a local guy who does it for 50 bucks. A dyno tune is a 100 bucks from him and he does great work. Either way, a well done chip is a good deal, it's just the dyno time and a good tuner that "could" get even more expensive after you have had your ECU socketed and chipped.
Old Oct 18, 2005 | 06:07 AM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
this is not only for the chip. it is for an entire ecu that is already chipped. but i'm not sure if it's a scam.
Old Oct 18, 2005 | 11:23 AM
Provocateur
On permanent hiatus
If it has a generic program on it, then it won't benefit you. Unless your car is strapped to a dyno and the chip is programmed with the proper A/F ratios and ignition timing, it is worthless.
I am still unsure as to why you need it. Are you running a setup where you need the extra fuel? This isn't Gran Turismo where you buy an ECU and get 15 hp from it.
Old Oct 18, 2005 | 11:33 AM
Running925's Avatar
Running925
Your Powder Coater
what is your reasoning for needing to adjust your ecu's values.
have you modified your car to the point that it doesn't run right on the stock values?
Old Oct 18, 2005 | 04:28 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
i'm getting the parts together for a turbo setup. trying to get everything before i start installing stuff so i can do it all at once.
