rear main seal...
if its your main u would be leakin from between block and tranny considering thats where the seal is... behind it is most likely the residual oil drippin back while you drive... and bakeoff ...that was a real constructive post...whore.... btw fix it soon crucial... u dont want it gettin on your flywheel and bukin up anything..
A REAR main seal is not on the REAR of the engine... That's what I posted as I did. It would be the MAIN seal in a transversely mounted engine. It's behind your flywheel where your crank comes out of the block. If you need help on pulling the tranny, let me know. I've done it about 85 times... EASY once you get it down.
Originally posted by crucial Si
just pulled off the valve cover and distributor, and the oring there isnt leaking. any other ideas?
and what kind of oil r u running?
