heater problems
Old Oct 13, 2005 | 05:53 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
Default heater problems
so i just put a new thermastat in my del sol to try to get the heater working and it's still not working, does anyone have a ideas of what could be wrong with it. it's starting to get a little cold and i hate the cold.
Old Oct 13, 2005 | 06:29 PM
Jafro's Avatar
Jafro
I'm made of meat!
Burp the radiator. You probably have air in it because of the thermostat replacement. Make sure the heater is on full blast and warm up your car with the radiator cap off. As it warms up, keep topping off the coolant until its at operating temperature. Then put the cap on. You should be good to go.
If you don't have the heat on and fill it this way, then you'll usually have a giant air bubble trapped in your heater core keeping it from circulating.
Old Oct 13, 2005 | 06:30 PM
Jafro's Avatar
Jafro
I'm made of meat!
EDIT: Browser wonkiness... double posterages...
Old Oct 15, 2005 | 01:42 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
so i just bleed the radiator and i still have no heat, so i took the heater controls apart to see if anything is not working correctly and that wasn't the problem either. so does anyboby have any ideas now? i need help bad.
