gas
Old Oct 12, 2005 | 04:31 PM
potter11's Avatar
potter11
Default gas
does the SOHC vtec require premium gas??? just wondering
Old Oct 12, 2005 | 05:24 PM
96GreenCivic's Avatar
96GreenCivic
Nope, I put the cheapest 87 I can find. Been running fine and a little easier on my wallet. I have a 96 Civic EX.
Old Oct 12, 2005 | 08:08 PM
2gr84u's Avatar
2gr84u
2gr84u
nope the stock motor can suck the cheap stuff happily unfortanatly my turbo z6 has to drink up on the good stuff
Old Oct 12, 2005 | 11:08 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
I think I read yesterday as I was reading a manual, that 86 or higher was recomended. It may have been 87 but either way, cheaper is better. Out west you can buy 85, and I'm a cheap skate. It ran good on 85 and I get even beter mileage out west. Not sure if it's the gas or the elevation or higher percentage of highway miles.
Old Oct 13, 2005 | 02:24 PM
1995Civic's Avatar
1995Civic
I hate ricers
Those motors actually run better on the regular unleaded (cheap stuff) rather than premium or even mid-grade. Unless you have a heavily modified motor. All it is, is a waste of money to put premium gas into that car.
Old Oct 13, 2005 | 04:20 PM
Jafro's Avatar
Jafro
I'm made of meat!
Running premium on that engine is a waste. It will actually make you run rich. Yes your ECU will make adjustments to correct for changes in fuel, air temp/density... Which means that you could get better gas mileage with higher octane fuel... but there's no need to run anything higher than 87 octane on a factory-spec Honda SOHC. Certainly not enough of a performance boost to warrant doing otherwise on your daily driver with gas prices where they are.
