help?
Old Oct 11, 2005 | 04:27 PM
urbanclassic's Avatar
urbanclassic
Default help?
I just got a 94 hatch cx model and planning to swap a d15b vtec, but somebody told me that you need a rpm window switcher or something like that, to run the vtec consitantly. is that true? or there another option on running the vtec.
Old Oct 11, 2005 | 04:29 PM
delsol161's Avatar
delsol161
d15b vtec? that's a new one on me. i run a d15b7, which is most deffinately not vtec...
Old Oct 11, 2005 | 04:31 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You haven't been around long, have you?
D15B is basically the JDM equivelant to the D16Z6 with .1L less and a higher comression. It is an SOHC VTEC engine.
First off, why would you want to run VTEC constantly? Bad idea...
Get an SOHC VTEC engine wiring harness to make it easier on you and then run the VTEC wires to the ECU. Simply run a P28 ECU and you're good to go. It's a simple swap. There is a sensor that is not on the intake maifold of your CX that isn't on the D15B. You might need to make provisions for that so you don't throw a code, but that's the only hickup about the swap. hih
Old Oct 11, 2005 | 04:40 PM
delsol161's Avatar
delsol161
you know i haven't been on long... you've helped me a number of times. all i was saying was that i wasn't aware there was a vtec version of my engine.
Old Oct 11, 2005 | 04:43 PM
urbanclassic
okay^^ the problem is that I don't have sohc vtec harness. I just have the plain obd1 harness that came with the non vtec engine. I mean it should work right, but I probably have to do some wiring?
Old Oct 11, 2005 | 04:45 PM
westcoaststyle
ya, that should work. You will need to run VTEC and VTEC oil pressure wires for sure.
Old Oct 11, 2005 | 04:47 PM
delsol161's Avatar
delsol161
BTW, what are the HP differences between d15b & d15b7?
Old Oct 11, 2005 | 04:48 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Does your new motor come with its harness? I just cut the vtec plug off the JDM harness and soldered some wire long enough to go through the fire wall and into the ecu. All you would need is a ground, vtec purge selenoid wire and oil pressure switch wired in. It sounds complicated. I even hesitated to do it for like a week. But when I did it, it took about 15 minutes tops. That includes smashing some spare sensors to get the little wire clips out.
Old Oct 11, 2005 | 04:50 PM
westcoaststyle
Oh, you will have to use a newer O2 sensor as well because the D15B uses a single wire O2, while your harness will have a four wire O2. FYI.
D15B is 125 chp: http://www.usedjapaneseengines.com/e...erformance.htm
Old Oct 11, 2005 | 04:53 PM
urbanclassic
what about the rpm switcher thingy, I don't know what they called but it's supposed to activate the vtec or else i'm just running on a plan non-vtec motor. I think they called it like rpm window switcher ? I don't know.
