Front intercooler, cold air intake
What is your thoughts about a cold air intake that has a intercooler front box in the grill. Insted of the orginal cone air filter?
What does happen when water gets into the engine? It just doesn't combust and takes awhile to go threw the system?
i think they work awsome.. just really have to look out for the water situation more than the normal cold air intake due to the fact that it really is sitting right out in front.
Might wanna use one of those AEM bypass valves.
on the other hand.. u'r probly not going to notice a difference, so save u'r money & go turbo!
Why would you want to give the impression that you have boost?
People look for that to try to pick you out for a race...
and like RUNNING 925 said, you basicaly can't drive in the rain...
And I've heard several times that the AEM bypass valves SSSUUUCCCKKK...
Stories about parts being sucked into throttle body...nasty schize...
So you want to use an actual FMIC as an itake? The intercooler is probably 150-250$ and you probably wouldn't see much more gain than a regular cold air, which I wouldn't use anyway because I fear hydrolock.
h:
