my civic wont start, just put in new clutch kit and replaced the starter too
Old Oct 9, 2005 | 10:42 PM
jrcivic's Avatar
jrcivic
Default my civic wont start, just put in new clutch kit and replaced the starter too
i replaced my starter cause it was shot, i did this while i was replacing my clutch too, my car wont crank now, the only thing that works is my emergancy lights, any idea on why this is goin on? any suggestions would help, oh yeah, its a 94 civic
Old Oct 9, 2005 | 10:54 PM
Wharbone's Avatar
Wharbone
When you say all that works are your emergency lights, do you mean no other light or electrical device in your car works?
Check fuses, battery.
Old Oct 10, 2005 | 04:36 PM
jrcivic's Avatar
jrcivic
i checked all my fuses, and i got my battery tested, battery is still good, got the battery charged too, all my fuses are good too, i still dont know what the problem is, my motor wont crank or anything....
Old Oct 10, 2005 | 04:56 PM
smallphobia's Avatar
smallphobia
One day when its quiet at your house, or wherever your car is. Take off your gas cap, have a friend turn over the car and see if you can hear your fuel pump. Itll be a buzzing noise..if not..get your pump and relay checked. Also..You can turn it over. and check your spark plugs to see if they are wet..Also...take out 1 spark plug...put it in the end of the wire..turn it over and look for spark..but make sure its grounded when doing this.
Old Oct 10, 2005 | 05:04 PM
teg92's Avatar
teg92
WHAT OK YEAH!
did you connect all your grounds back?
Old Oct 10, 2005 | 05:11 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Did the clutch install well? I know the rotor on the starter goes into the bell housing and is exposed to the clutch and flywheel. I wish I could help, but I didn't experience any problems starting after my clutch install. I'd start from the pump, then work your way up to the sparkplugs and coil.
Old Oct 10, 2005 | 09:02 PM
94civicEX's Avatar
94civicEX
I got worms.
This is what I was going to say.
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 10, 2005 | 10:42 PM
bambbrose's Avatar
bambbrose
possibly forgot the big tranny ground. it'll affect a lot of stuff.
Old Oct 10, 2005 | 10:51 PM
jrcivic's Avatar
jrcivic
thanks alot for all of your suggestions guys, ill try them all this weekend and double check everything again, ill tell you guys what happened
Old Oct 10, 2005 | 10:56 PM
Omniscient's Avatar
Omniscient
But it's tuesday! That's to long!
