Honda Civic Throttle body
hi does any body have a pic of a 92-95 Eg civic 1.5 SOHC and show me where the:
1. throttle body is
2. the little screw that you can adjust to make car idle better
3. where the Idle Control Valve is.
i would much appreciate it. as my car idle's very low and vibrates like mad. i was told to adjust this screw but can find it.
thanks
1. throttle body is
thanks
No, that's the intake. The throttle body is where your throttle cable connects to. It is between the intake piping from the filter and the intake manifold pictured above. If you look at it on the side where the intake pipe connects to it you should be able to find the adjuster screw. I believe the IACV (Idle Air Control Valve) should be on the back of the intake, but I'm not sure on the Dseries...
This should be where the adjuster screw is:
