b16a
Old Oct 6, 2005 | 12:45 AM
Dark_kiseki's Avatar
Dark_kiseki
Default b16a
Hey guys I finally have the option to put a b16a into my 94 del sol. I been doing some searching and looking and I was wondering if this was true. http://www.enginereplacement.com/htdocs/hondaswap.htm says, "92-Up Civic/Del Sol, 94-Up Integra needs the B16A2, B18C5, or B18C motor. These motors bolt straight in and will work on models that are not OBDII, unless you change the entire wiring harness or use an adapter. You also need to get axles from a 94-Up Integra GSR or 99-Up Civic Si." Bolt straight in as in I don't need any new engine mounts. Another thing is I plan to do a auto to manual conversion. Do i need a new tranny mount for that as well? Here is the place I plan to by my b16a from http://www.jazzproparts.com/ProductD...ductCode=B16a2
from the top of my head I know I need a clutch assembly lines, pedals, clutch master/slave. I have no idea what the clutch assembly lines are and if you guys know can you direct me to a cheap price. Thanks a bunch guys.
