Cooling fan switch.
Old Oct 4, 2005 | 06:09 PM
civicburner's Avatar
civicburner
Default Cooling fan switch.
When i change my cooling fan switch do I have to drain my coolant first?
Old Oct 4, 2005 | 06:36 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Like the plug that goes into the fan? Or the temp sensor that tells the fan to kick on?
Old Oct 4, 2005 | 06:54 PM
civicburner
The temp sensor
Old Oct 4, 2005 | 07:07 PM
Omniscient's Avatar
Omniscient
You don't have to drain it, but you have to bleed the air out afterwords.
Old Oct 4, 2005 | 07:10 PM
civicburner
Ok. Since the thermostat will be closed there should be no coolant in the lower hose, and I won't have to worry about coolant leaking out. Right?
Old Oct 4, 2005 | 07:44 PM
Omniscient's Avatar
Omniscient
When I did my thermostat there was coolant behind it and the sensor is behind the thermostat.
Old Oct 5, 2005 | 11:41 AM
civicburner
One other question...My radiator fan hasn't been coming on for over a year now, but the only reason I wasn't too concerned is because my car never overheats. I live in NY, so I'm, constantly in traffic, but the temperature guage is always at a normal level. Is it even necessary for me to fix the fan?
Old Oct 5, 2005 | 11:44 AM
extensioncordy's Avatar
extensioncordy
EG6
what do you think is normal?
Old Oct 5, 2005 | 02:23 PM
Omniscient's Avatar
Omniscient
Um, my fan decided not to work just ONE TIME and I ended up blowing my d15b7.
Old Oct 5, 2005 | 05:07 PM
civicburner
Normal = guage about half way.
