fuel filter
Old Oct 1, 2005 | 09:40 AM
huge230's Avatar
huge230
Default fuel filter
I have been trying to change my fuel filter but cant get the bottom where it connect to the line of. I used tonnes of penetrating lube but still nothing. any of you guys have this problem? what did you do?
Old Oct 1, 2005 | 10:01 AM
extensioncordy's Avatar
extensioncordy
EG6
i had that problem...i just kept spraying WD-40 every ten minutes for about an hour...and then it came right off...
Old Oct 1, 2005 | 10:02 AM
extensioncordy
EG6
try using like a breaker bar...haha just be careful not to break any thing...you may have to cut the lines and get new ones if its that bad
Old Oct 1, 2005 | 05:47 PM
junior-ae's Avatar
junior-ae
I don't know if I was lucky or if I just waited long enough after spraying the bolt with penetrating fluid. I used two wrenches; one on the top of the filter to hold it in place and another on the bottom to loosen the bolt.
I would strongly recommend using a flare nut wrench on that fitting bolt, not just an open-end one. It'll give you a better grab, but also keep you from rounding the fitting bolt.
Old Oct 2, 2005 | 03:19 AM
Civic2Scooby's Avatar
Civic2Scooby
two flare nut wrenches and some penetrating lue did the trick on mine.
Old Oct 2, 2005 | 08:31 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
Flare nut wrenches for sure. You'll be surprised what the right tool for the job will do.
Old Oct 2, 2005 | 09:30 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
you are turning it the right way...arent you?
Since its upside down, and all...
Old Oct 3, 2005 | 06:45 AM
Running925's Avatar
Running925
Your Powder Coater
just need a lil muscle behind that wrench!
it't will budge
Old Oct 3, 2005 | 08:40 AM
'98 EX RED's Avatar
'98 EX RED
King of the Auto Civic
Yeah, get 2 wrenches in there and use those muscles we all know you have ;-)
