engine swap ideas
Old Sep 18, 2005 | 06:40 PM
mikesta21's Avatar
mikesta21
93preludesi
Default engine swap ideas
whats the best engine swaps for a civic gen. 96-00
its for a friend of mine
he was thinking GSR,
does h22 fit?
clueless but i wanna let him kno some recommendations
thanks again.
Old Sep 18, 2005 | 07:24 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
yes an h22 will fit with mounts....
Old Sep 19, 2005 | 06:32 AM
baseballer03's Avatar
baseballer03
H22 will fit but very heavy...my opinion would be the b18c5 or the k20<expensive...both are huge power plants but the engine selection really plans on what he wants to do with the car...
Old Sep 19, 2005 | 08:14 AM
Omniscient's Avatar
Omniscient
warm butter on toast
No, the h22 isn't "very heavy" It's heavIER but not to the point where it even really makes a difference in drivability. With good mounts and a good suspension you'll be fine.
Old Sep 19, 2005 | 09:03 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
H22 will fit but very heavy...my opinion would be the b18c5 or the k20&lt;expensive...both are huge power plants but the engine selection really plans on what he wants to do with the car...
K20. MMMMMMMMM GOOD, if you got the $$$$
Old Sep 19, 2005 | 09:23 AM
raiden571's Avatar
raiden571
turning u inside out
id go with a b18b or a b18c1. either way, build and boost, or just boost on stock internals.
b18a/b- good torque, ok hp, great for turbo, very abundant, easy to install, cheaper that other b18's
b18c1-good horsepower, nice stock or with bolt ons, but expensive and higher compression then a b18b
b18c5- very nica N/A motor, not good for boost. very expensive and harder to get ahold of
b16- basically a dohc d16, dont feel the power until u rev it up. ok for boost, but also has higher compression, easily found and abundant, relatively cheap
h22-more modification is needed for an h22. there nice because they can be found relatively cheap, until u have to buy everything extra for the conversion. weigh a lil more, but make up for that with power. forged pistons can not be used unless u have the block resleeved.
k20- very expensive, swap is alot more involved then a b18/16 and even an h22 rom what i hear. after all is spent, you could have built a b18, make 400+ with a turbo and still have money left for a case of beer to chill with ur friends.
Old Sep 19, 2005 | 09:25 AM
Running925's Avatar
Running925
Your Powder Coater
b18, easily done! Best bang for the buck
Old Sep 19, 2005 | 09:56 AM
saber1's Avatar
saber1
nice guy
I'd say B18C for NA power (unless you want to cough up the additional $$$ up front for the B18C5). Nor boost you could go with either the B18B or B18C. Build either wisely and you would have a very fun and quick ride.
Old Sep 19, 2005 | 07:20 PM
flatliner's Avatar
flatliner
Fix It
in the mean time just add nos and hit it at every light.
Old Sep 21, 2005 | 11:32 AM
mistacee's Avatar
mistacee
Zc powered ED9
does h22 fit?.
How many times has this been covered and talked to death!
