Air/Fuel wont work?!?!!?!?!?
Old Sep 13, 2005 | 03:59 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
Default Air/Fuel wont work?!?!!?!?!?
Ok so i got and a/f gauge a long time ago and when i bought it i got it for dirt cheep cause it was damaged so when the guy put it in he said it wouldnt work well i got currios today so played with it. I moved where he had it... off the ecu.. to the actual o2 sensor and i actually got some reading from it. Well it wont read right, like it will jump all over the place like its not gettin a good connection. I tried just wraping the wire around the bare striped o2 wire and then i bought these little connecters. Neither one of those ways worked but if i wiggle the wires, that is when it will jump around. any help will be great thanks guys
Old Sep 13, 2005 | 05:08 PM
qtiger's Avatar
qtiger
Do you mean it jumps back and forth rich to lean? That's exactly what it should be doing. That is how inaccurate the stock O2 sensor is.
Old Sep 13, 2005 | 05:18 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
No.... I know what its supose to look like ... But right now it just sits at rich... like the last block on the gauge. That is where its been sence its been in the car and when i messed with it today it finally had some type of reaction so i know the gauge works but it wont stay working... basicly i need to kno a good place to hook it up at and what the best way to splice it into it.. thanks
Old Sep 13, 2005 | 05:26 PM
qtiger's Avatar
qtiger
Rich is low voltage, lean is high voltage. So if it's not getting good signal it would be on the rich side.
I would solder directly. That's what I just did installing my A/F gauge.
Old Sep 13, 2005 | 05:40 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
sweet ok thanks
Old Sep 13, 2005 | 07:50 PM
Paul's Avatar
Paul
Eater of Rice
you aren't running a blue box by chance are you?
Old Sep 14, 2005 | 02:03 AM
Kabooki's Avatar
Kabooki
I had a similar problem with my autometer phantom a/f gauge. it seemed to allways sit on the first (left) light and never move from there unless I jiggled the wire, then it would just give random readings. Someone told me that some gauges work in the range of 0-1 volt and some work from -1 to 0 volts. This seems like it would cause the problem I am having. I tried it on 3 different hondas connected straight to the O2 sensor.
Old Sep 14, 2005 | 03:07 AM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
nope...
Old Sep 14, 2005 | 04:08 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
Originally Posted by BOOSTED-EK
i got it for dirt cheep cause it was "damaged" so when the guy put it in he said it "wouldnt work"
You think this might have anything to do with it?
Old Sep 14, 2005 | 04:18 AM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
Well i thought that is what it was but when i got into my car to start driving to school it worked off and on all the way to school... if it wasnt working today it was completely blank as if it wasnt gettin any power, but i know it was... i dont know i htink im just goin to solder it and let it be cause as long as its getting a good connection it works great.... thanks for you guys help....
