Torque Spec on oil drain bolt
Old Sep 10, 2005 | 09:23 AM
thatoneguy's Avatar
thatoneguy
MMMM.....BEEEEER
Default Torque Spec on oil drain bolt
Does anyone know the torque spec on the engine oil drain bolt? Oil is leaking and I want to make sure it is on tight enough...
Old Sep 10, 2005 | 09:40 AM
qtiger's Avatar
qtiger
Use your smallest ratchet and turn it maybe 1/4 to 1/2 turn past hand tight. If you overtighten you'll strip it and then you'll really be leaking oil.
Do you have a gasket washer on the drain bolt?
Old Sep 10, 2005 | 10:24 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
15-17ft/lbs
If oil is leaking did you use a crush washer? Did you put a coating of oil around the drain bolt?
Autocross Help Page
Old Sep 10, 2005 | 10:42 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
:werd: dont gorilla tighten it.
Old Sep 10, 2005 | 10:48 AM
thatoneguy's Avatar
thatoneguy
MMMM.....BEEEEER
Thanks. My last oil change was at an oil change place and oil has been leaking since. There and at the transmission, so I need to make sure that they are tight. If need be I will make a gasket to put on or use a crush washer as recomended. Thanks for all of the help guys...
Old Sep 10, 2005 | 05:50 PM
CivicSiRacer
Crush washers are like $0.05 at Honda I got like 50 But you tighten the drain bolt TOO hard it can strip the threads. The pan is aluminum.
Autocross Help Page
Old Sep 11, 2005 | 07:32 AM
thatoneguy's Avatar
thatoneguy
MMMM.....BEEEEER
Thanks for the heads up. I am thinking about getting one of the drain plugs that allow you to connect the hose straigt to it. This time, I will make sure I don't tighten it too much, don't want to have to helicoil it...
