engine light
I just got my car out of the shop,it was there for 2 months because it was overheating. they replaced the head gasket,cylinder head, radiator, thermostat, and coils. This cost me about $2,600. And now when i take it home my engine light comes on and the car begins to shake, what can it possibly be now??....i have a 2002 Honda Civic Ex...someone please help or give me some input...thanks.
I dunno. When my engine light comes on, I just disconnect the negative battery cable to reset the ECU and forget about it.
The "Check Engine" light has to do with you emission sensors. I just recently had that light pop up when i was on a road-trip. I put the silencer on my exhaust for the trip and it ended up causing a back-up in the system and one of my sensors/valves needed to be replaced. It ran me about $300 at the local Honda dealorship.
And you say that your car is shaking too??? Sounds like definate mechanic-incompitance. Take your car to a better shop next time. |
why did they replace the cylinder head? was there damage from the overheat? did you use water or coolant?
u should take it back to that shop an tell them to fix what ever they did, at no charge
Just out of curiosity....what kind of shop did you take it to ???
yeah there was damage due to overheating..they had to replace everything |
i took it to a honda dealership |
