burning oil?
Old Aug 29, 2005 | 03:38 PM
Hatehonda.net's Avatar
Hatehonda.net
Default burning oil?
I've always heard from the local honda guys that when vtec kicks in it will burn a sustantial amount of oil. When i kick vtec in a puff of smoke comes out of the exhaust. And it took me a couple of days to figure out why my vtec wasn't working(not enough oil) that was after i took apart the selanoid(cant spell) and check all wiring. NEWayz does anybody here share that same characteristic
Old Aug 29, 2005 | 03:43 PM
VTEC-Power's Avatar
VTEC-Power
well if you don't have enough oil VTEC won't kick in, it is as simple as that
Old Aug 29, 2005 | 03:45 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Does your oil pressure light come on? Are you throwing any CEL's?
You might be burning oil. Which motor do you have and how old is it. Check your oil levels daily and see how much is burning. If you are losing oil, do a compression test to find out exactly what is causing you to burn oil. (piston rings, valves, etc.)
Old Aug 29, 2005 | 03:46 PM
Hatehonda.net
yeh i know that but what i'm asking is if anyone burns oil like me
I but about a quart in every week and a half
Old Aug 29, 2005 | 03:49 PM
asiandoood's Avatar
asiandoood
Get a compression test and leakdown done. It'll tell you exactly what is wrong. Most likely your valve seals or piston rings are bad. Or it can be as simple as a PCV valve being clogged.
Old Aug 29, 2005 | 05:09 PM
VTEC-Power's Avatar
VTEC-Power
I was going to say valve seals
Old Aug 29, 2005 | 09:30 PM
sollivier's Avatar
sollivier
same problem as me spent 2300 just repairing my engine and it still needs a ring job to stop the smoke and oil burning check your pvc valves, mine where screwed fixed them and its not as bad. but your best bet is a ring job.
