oil change time
Old Aug 27, 2005 | 08:18 AM
97civicEXVTEC's Avatar
97civicEXVTEC
Default oil change time
what oil should i use or doesnt it matter? i have no clue what was being used on it before, i just bought the car a month ago with just under 150k miles.. thx
Old Aug 27, 2005 | 08:49 AM
AliasNeo's Avatar
AliasNeo
uhh, if is dinosor oil id stick with that, 5-30 should be fine, if its burning oil, u can try a 10-30 would reduce it cause its thicker... umm if theres synthetic in there go with synthetic
im not sure if you want to switch to synthetic or not because of the milage...
Old Aug 27, 2005 | 08:55 AM
mikemerc85's Avatar
mikemerc85
Git-R-Done
5-30 and 10-30...it doesnt matter except that like alias said 10-30 is just thicker..dont go with full synthetic...theres no need to.
Old Aug 27, 2005 | 09:04 AM
AliasNeo's Avatar
AliasNeo
at 100xxxk miles i switched to full synthetic, but i changed the oil again twice for 2k miles so one at 1k and another 2k... when i switched and used the 5-30, it did burn a bit so i use 10-30 now and its reduced alot unless i ride vtec alot lol
Old Aug 27, 2005 | 04:35 PM
flatliner's Avatar
flatliner
Fix It
wow 150k and you already are blowing by. I cannot believe its valve seals, perhaps you need to update your pcv.
