radio not working..low idle
Old Aug 14, 2005 | 05:28 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default radio not working..low idle
i just wired my head unit in only to find out it wasnt working.. i checked the radio fuse and it was blown so i replaced it.. the head unit would not turn onbut when i hit the cd eject button u can hear it working.. so i rewired it but now the cd eject motor isnt even working.. its really pissing me off so let me know anything you can..
problem 2.. little more serious..
i go to start the car but instead a loud 'pop' comes from the battery and the car power shuts off.. after figiding with the negative cable, power returns.. but when i start the car, the needle wont even jump past 1k an sits down at 200-300 rpms.. i dont know if this is falty o2 sensor, fuel pump, or throttle body..
Old Aug 14, 2005 | 06:08 PM
VPUPPY's Avatar
VPUPPY
did problem two start after problem one? and for the radio, did you cut the factory harness or did you buy a harness that plugs into the factory?
Old Aug 15, 2005 | 01:26 PM
97civicEXVTEC
problem 2 started after problem one.. but now for some reason problem 2 has stopped and i did nothing to change this? and i cut the factory harness.
Old Aug 15, 2005 | 07:51 PM
97civicEXVTEC
Old Aug 15, 2005 | 07:59 PM
Running925's Avatar
Running925
Your Powder Coater
first off.. u'r an idiot for cutting the factory harness.. with that said, it sounds like you have other un-related electrical problems with your car. The poping sound was probably your battery contacts just rejecting them selves, make sure that they are clean (wire brush if not), & make sure they are tightened securly (via wrench!).
hopfully when u cut the factory harness u didn't make one big cut, but u cut each wire individually. If not then you crossed a positive charge with every other wire in there even if the car was off due to the constant 12v power for memory!
Old Aug 15, 2005 | 08:10 PM
97civicEXVTEC
well yea im and idiot for cutting the factory harness, and yes i DID make one big cut, and guess what, blown fuse.. but the fuse was replaced and it worked for a little bit and then stopped all together..
Old Aug 16, 2005 | 01:48 PM
VPUPPY's Avatar
VPUPPY
rewire your radio once more. visit www.installdr.com for the correct wire colors for your radio. its under the quick radio wiring info section.
Old Aug 16, 2005 | 05:21 PM
97civicEXVTEC
i already used that and it stil ldoes not work.. and if i stall the car the low idle returns
