engine temp problem...
Old Aug 13, 2005 | 10:34 PM
mini-me civic's Avatar
mini-me civic
Default engine temp problem...
when i first start the car and let the car warm up the engine temp gauge goes up slowly like normal... but when i start driving the temp gauge goes down back to C... as i keep going the temp gauge goes back up to normal usualy alil bit below half way.... the temp gauge seems to keep dropping and rising back up.. also i noticed when i go down hill the temp guage goes down to C.. so yeah idk if it could be my thermostat or just a wiring problemm .. ne one had dis happen to them or know wat the problem is.. plz help..
Old Aug 13, 2005 | 10:44 PM
VTEC-Power's Avatar
VTEC-Power
sounds like the thermostat to me
Old Aug 13, 2005 | 11:05 PM
mini-me civic
if there was a problem with the theromstat would the CEL come on..
Old Aug 14, 2005 | 01:34 AM
abdelsol's Avatar
abdelsol
Sounds like the thermostat opening and closing. Sitting and idling engine will be hotter. Moving cools the engine. going downhill is a lighter load on engine less heat and cooler.
Old Aug 14, 2005 | 08:47 AM
VTEC-Power's Avatar
VTEC-Power
no, my thermostat was messed up and a CEL never came on
Old Aug 14, 2005 | 09:06 PM
mybluesnafu's Avatar
mybluesnafu
CEL? maybe I am too green to be on here... I would consider replacing the thermo as well. You can check the mechanical workings of your temp gauge by pulling off the lead that connects to the temperature sender (located on the thermostat housing) and ground it. If you ground the lead the needel will move all the way up to H, have someone sit in the car and check it out.
-Tom
Old Aug 14, 2005 | 09:25 PM
mini-me civic
where is the thermostat located??
