codes...
Old Aug 1, 2005 | 10:50 AM
delsol161's Avatar
delsol161
Default did this cause my smoke?
Car smokes @ high RMPs. also sprays soot (almost appears to be oil) @ idle and all RPMs. i need to know how to check the codes on my '94 del sol. i've never learned. if anyone can tell me, i'd appreciate it.
Old Aug 1, 2005 | 10:55 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Online resources sticky ^^^
Old Aug 1, 2005 | 10:59 AM
delsol161's Avatar
delsol161
thanks
Old Aug 1, 2005 | 03:42 PM
delsol161's Avatar
delsol161
hey guys, i just ran my codes and here's what i got.
7 - TPS Sensor
41 - Primary O2 Sensor Heater
I know my tps is bad, my rpms used to jump really bad @ idol until the motor warmed up, but i changed it. i'm not worried about that. could my Primary O2 be the cause for the soot @ idle, and smoke @ high rpms? i recently changed out my Catolytic converter... any connection bewtween all this stuff?
Old Aug 1, 2005 | 05:05 PM
westcoaststyle
A bad O2 will cause soot because it's unburned fuel. The ECU sees the car as running really lean because there is no O2 signal so it richens up the air/fuel mixture to compensate. Fixing the O2 problem will both fix your smoking problem and give you better gas mileage.
Old Aug 1, 2005 | 05:10 PM
delsol161's Avatar
delsol161
that makes a lot of sense, cuz my milage sux too well, thank you. i will buy a new one, and rewire the mess the previous owner made of the harness for it. i'll let ya know if that works. hey, is $58 a decent price for a new o2?
Old Aug 1, 2005 | 08:07 PM
westcoaststyle
Ones from honda are over $200. You decide.
Old Aug 2, 2005 | 07:57 AM
delsol161's Avatar
delsol161
hah, thanks... point taken
