need help with CERL codes...
Old Aug 1, 2005 | 09:08 AM
Joshcivic00's Avatar
Joshcivic00
Default need help with CERL codes...
I just did the self diagnostic and i am getting the codes 1(1 slow beep),2(2 slow beeps), and 7(7 slow beeps)! can anybody help me to figure out wha the problem is???i see code lists for other years but not for a 2000 Civic EX(the latest is a 1998 civic)are the lists the same??? if so it is showing that axygen sensor A(primary) and b is not working and that the TP sensor is not connected or something!
p.s. i just hooked up a greddy turbo kit with emanage and the car is wanting to bog in the low rpms and gets worse to were it like goes on safemode and it struggles to get to 3k rpms(only happend once) can anybody help???
Old Aug 1, 2005 | 09:29 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
The lists are the same.
Your explanation isn't making sense. And where are you hearing beeps? The codes are measured in flashes. Long flash = 10, short flash = 1.
Example: 3 long, 5 short = code 35.
Old Aug 1, 2005 | 09:42 AM
Joshcivic00
i said beeps but it was in flashes
Old Aug 1, 2005 | 09:48 AM
westcoaststyle
So, you have:
1 - Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 - Oxygen Sensor "B" defective circuit or unplugged / defective sensor
70 - Automatic Transmission malfunction with the automatic transmission controls
I would bet that you wired up your eManage incorrectly.
Old Aug 1, 2005 | 10:07 AM
Joshcivic00
well i know that my D4 light on the dash is flashing for some odd reason!
Old Aug 1, 2005 | 10:11 AM
westcoaststyle
Yup, you wired something very wrong. I'd turn the car off, disconnect the battery, and triple check your wiring. I'd have someone else do it actually. It's like reading a paper you wrote, you can easily miss the little mistakes where someone else will see them clearly because they have a fresh perspective.
Old Aug 1, 2005 | 10:32 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is my guess too. Either that, or you didn't set the Emanage correctly.
Old Aug 1, 2005 | 10:35 AM
Joshcivic00
when u get the emanage that is specifically for a 99-00 civic ex, does it still need to be slightly tuned??should i just try and get it to a nearby shop and let them check the wiring out and stuff then???
Old Aug 1, 2005 | 10:42 AM
westcoaststyle
It will have the basic maps for you to drive the car. I wouldn't go crazy on the basemap.
You can take it to a shop to have them check it, but why pay for it? Just go over it until you see the mistake.
