speed odometer problem: need help asap
Old Jul 31, 2005 | 08:10 PM
del sol's Avatar
del sol
Default speed odometer problem: need help asap
i have a 95 del sol si, and when i press the gas or punch it, the odmeter speed stick doesn't respond to my actual speed, it freezes or skids around. For example when i'm going really 60mph, it says i'm going 45, and then when i make a turn i'm going 5mph tops and it says i'm going 40mph, it freezes up or the speed skips or jumps up and down. Need help asap, does any1 know how to fix this problem
Old Jul 31, 2005 | 09:04 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Might be your vehicle speed sensor, mine did that once because it was a little loose.
Old Jul 31, 2005 | 09:14 PM
del sol's Avatar
del sol
wheres the speed sensor located at
Old Jul 31, 2005 | 09:27 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
On top of the tranny.
Old Jul 31, 2005 | 09:32 PM
mini-me civic's Avatar
mini-me civic
my speedometer use to jump all over too... for some reason my alternator fuse under the dash was burnt out so i replaced it and my speedometer worked fine... try check that out or yeah could be ur speedsensor...
