tapping after valve adjustment
Old Jul 31, 2005 | 01:51 PM
BlAcK_eL's Avatar
BlAcK_eL
Default tapping after valve adjustment
ok so i have a B16a2 and did a valve adjustment, set the stock spec.
intake to .006
exhaust to .007
at idle is seems ok, but when i drive or rev the motor a little i hear a tapping
did a compression test and and got
c1 - 200 psi
c2 - 195 psi
c3 - 191
c4 - 198
could some help me find what the problem could be
thanks
Old Jul 31, 2005 | 10:13 PM
VTEC-Power's Avatar
VTEC-Power
run fuel system cleaner. My B16a ticks and there is nothing I can do
Old Aug 1, 2005 | 05:26 AM
Running925's Avatar
Running925
Your Powder Coater
why the hell would fuel system cleaner fix tapping in the head :slap:
on another note, i'm not sure of the milage of your motor but there is a posibility that the wear patern on your cam lobes is off due to accessive wear and it could be making the taping noise due to an in-consistantly sized cam lobe.
or, maybe your missing a rod bearings & the rod is slapping against the crank as it goes up & down! it's hard to say without hearing it..but how many miles are on your engine & whats the condition of it..
Old Aug 1, 2005 | 12:46 PM
extensioncordy's Avatar
extensioncordy
EG6
mine tick...and they wont stop
Old Aug 1, 2005 | 05:14 PM
VTEC-Power's Avatar
VTEC-Power
So it cleans the valves :slap: I have the same problem and I have a fresh motor swap in my car
Old Aug 2, 2005 | 04:10 PM
hybridhondahatch's Avatar
hybridhondahatch
for that added pep
just redo it thats all you can do, its not hard just more of a pain in the ass than anything.
Old Aug 2, 2005 | 04:39 PM
VTEC-Power's Avatar
VTEC-Power
redoing it won't fix it, I have tried several times
Old Aug 2, 2005 | 04:50 PM
Running925's Avatar
Running925
Your Powder Coater
if you hear tapping, after a valve adjustment, they aren't properly adjusted. If they were, the lash wouldn't be so effective that u'd hear it!
Old Aug 2, 2005 | 04:56 PM
VTEC-Power's Avatar
VTEC-Power
I don't think the problem is the valves, mine does it even after I changed the valves, got a valve adjustment and some minor head work. Mine is wierd though it started after I got a oil change, so maybe changing your oil might help
Old Aug 2, 2005 | 05:01 PM
Running925's Avatar
Running925
Your Powder Coater
4Banger69 - u should really stop posting or somethin..
some of the other members & i have come to the conclusion that your hurting people more than helping them! your last comment about changine the oil due to a valve adjustment being done out of spec is just absolutly off the wall & makes no since. Maybe if he swaps windshields it will give him self adjusting tire pressures too!
