Civic EXi 2000 brake info
Old Jul 29, 2005 | 06:04 AM
TriniSpeed's Avatar
TriniSpeed
Default Civic EXi 2000 brake info
What type of brakes to I have on the front and rear? Are they callipers all around? Or drums ont he back? If they are drums does anyone have instructions on how to replace drum brakes?
2nd problem....What is an auto 2000 civic Exi suppose to idle at in park?
3rd problem...When I turn on the ac unit inthe car I hear a louder noise than the engine outside. What can I check for?
Thanks alot guys!
Old Jul 29, 2005 | 06:09 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
1) Not sure about the EXi. If it's your car you can just look at it and tell. If the front doesn't look like the back then it's disc/drum. Do a search for Disc Brake Conversion and you'll find your answer.
2) About 800 RPMs
3) What kind of noise? It could likely be the condensor fan turning on. Try to be more specific.
Old Jul 30, 2005 | 08:10 AM
hp0786's Avatar
hp0786
3) check your AC level. get one of those kits that refill the AC. I once put in too much and it started to shake alot and too little can probably do the same.
