This is starting to get old...
Old Aug 13, 2005 | 08:39 AM
  #31
Jafro's Avatar
Jafro
I'm made of meat!
I just got home. It's hot as a MOFE!
That's the wastegate actuator line then... Awesome. Sounds to me like you probably found the problem. It's an hour later, how's it going?
You know... if the line's clogged, then the only reason you'd have no boost is if the pressure was trapped in the line between the clog and the actuator causing the wastegate to stay open. It's supposed to be closed under vacuum pressure.
Old Aug 13, 2005 | 09:58 AM
  #32
2gr84u's Avatar
2gr84u
2gr84u
well ive got the wastegate working now, and its tightend as far it can go, but still no boost. That covers everything in your PM, im waiting for it to cool down a bit outside and for the engine to cool off again and ill go do some more leak testing. I guess the next thing will be taking the turbo off the car to check for cracks. Give me a call at my house if your still game for tommorow or later today
Old Aug 13, 2005 | 02:54 PM
  #33
2gr84u's Avatar
2gr84u
2gr84u
well after about 8 hours of work on the car today i think it might actualy boost!!! It held 5 psi when i had the compressor connected to it. Im about to head over to a friends house so lets hope this thing shows me something!.
Old Aug 13, 2005 | 08:02 PM
  #34
2gr84u's Avatar
2gr84u
2gr84u
alright finnaly got some positive numbers on the guage. The problem how ever is that those postive numbers only show up at 5-7k. I think and i may be wrong, that sence the seals on the turbo are done, so i think that after I get the turbo rebuilt i should some some better performance. I think I still have some small leaks to find though.
Old Aug 16, 2005 | 05:09 PM
  #35
2gr84u's Avatar
2gr84u
2gr84u
Alright im about 100% sure ive finnaly got this thing figured out!! Today i finnaly got my first chirp from the BOV while boosting 3 psi. The wastegate has a bit of a wiggle to it so im gonna use some washers on the actuator to pull things tighter. The other thing that i think will spur results is getting rid of this stock cat, and throwing on either a test pipe or high flow. The problem im looking at now is i cant safly test for higher boost till i chip my ECU. So is there anyone in VA that can come and chip my ecu for me?
Old Aug 17, 2005 | 05:48 AM
  #36
Jafro's Avatar
Jafro
I'm made of meat!
If any ol' ECU can be chipped, I have a P05 from a '92 CX that you can have so you can keep your car on the road. Gee, I wonder where that one came from.
Old Aug 17, 2005 | 06:08 AM
  #37
2gr84u's Avatar
2gr84u
2gr84u
thanks but if i did that id have to change it into a vtec ecu. Ill just have to see if Kai can come up here and take care of it it with out to much down time heh
Old Aug 18, 2005 | 05:04 PM
  #38
Redcivic's Avatar
Redcivic
One of the original OG's
Yunkyard turbo kits blow.
Old Aug 18, 2005 | 06:34 PM
  #39
2gr84u's Avatar
2gr84u
2gr84u
sure do, thats kinda the point
Old Aug 19, 2005 | 09:10 AM
  #40
Redcivic's Avatar
Redcivic
Well obviously yours is not blowing much.
