humidity=CEL WTF?
Originally Posted by Flatland2D
Do you mean will the light be cleared away after you've gotten the code off? If so, then no, it will stay on as long as the error is active. Resetting the light and error codes usually involves disconnecting the battery for about 30 seconds and it should clear.
If it is water getting into your engine, get the problem fixed ASAP before permanent damage takes place.
Jumping the plug will turn on the CEL for you to read the codes. It will spit out all the codes and then repeat itself. Your best bet is to see what codes you have stored and start looking from there. That should give you a good place to start looking for a problem.
