installing oil/ feul lines
I have a 00 civic that I just put turbo in. all I need to do is connect oil and vac lines. please tell me what to do so i can drive my car. what lines run from the turbo and where it does. And also what are the names of the things I need. Thank so much. Anthony.
The oil return line runs from the turbo to the oil pan.
The vacuum hoses run from the fuel pressure regulator hose to the BOV and wastegate.
Originally Posted by Shmoo
The oil feed runs from the back of the block where the oil pressure sender is to the turbo.
you didn't research this stuff prior to installing your turbo?!?!
i'd probably buy an oil line kit from stealthmode on www.homemadeturbo.com
his kits are cheap, good quality and include all you need. your going to have to drill a hole in your oil pan for the return.
also make sure to use teflon tape or pipe dope on all the oil fittings to protect from oil leaks.
although it has been done, the fpr line is really small to run your bov and your wastegate. i would run them off a bigger vac line on the mani. or atleast run the wastegate off a bigger one.
you need plastic t's and vac hose to connect these
