Kinda embarassing question.
Eh. Ok. You know on the canister hooked up to the fire wall with the two hoses going in, and the cap on top that says PCV with the tiny hose coming out? Where does that hose go? My friend attached it (I think) and now it's unattached and chilling in the clap thingy on the intake hose. I have no clue where it goes. This is on a b16a by the way. God I feel so dumb. I can put an engine in, but I can't figure out where the hose goes.
It attaches to a nipple underneath the intake manifold.
It is a bitch to reconnect if the bracket holding the manifold to the block is still there. Regardless, get a new hose and reconnect it.
I had to re-corret my post. So I don't know if my case is any different.
Re-correction: Ok, if you look at the pdf attachement, one of the lines says to evap purge selenoid valve. That's the one that's not hooked up.
