why is it overheating?
Old Jul 6, 2005 | 08:33 PM
Oo_azNite_oO's Avatar
Oo_azNite_oO
Default why is it overheating?
Everytime when I turn on the a/c in my civic and leave it running for more than 5 minutes during idle, I see the temperature needle going up. Why is this happening? I already check the coolant, both fans are running fine, and I also got a new thermostat. I have never had this problem with my car until about 2 weeks ago when it happen. By any chance, do u think that the timing belt could affect the overheating? The reason why I brought this up is because ever since its was changed, the belt has been making this low whining sound randomly and I think its stressing out the engine. Any explanation?
thaxs
Old Jul 6, 2005 | 08:55 PM
flatliner's Avatar
flatliner
Fix It
belt is too tight. as far as overheating, now that we know this much you have tried. Verify the thermostat you installed has a flow-back valve in it (a little metal squashed peanut shaped on the side of it.) . If it did and you did run heat with cap off and the correct coolant process. then you probally got a stopped up orifice/expansion valve or the drier is flooded with ac dye and oil. one other thing. verify the whinning is not your compressor that could also cause problems.
