lights blinks...
Old Jul 5, 2005 | 10:03 PM
mini-me civic's Avatar
mini-me civic
Default lights blinks...
when i first start my car all the lights in car including cluster lights, my headlights, tailights seems to blinks or dim repeatedly.. my car seems to bog also... but if i let the car run for 15 minutes the dimming stops and the cars runs fine... idk if its the altenator or battery... idk wat da hell is wrong .. ne body know...
Old Jul 6, 2005 | 07:58 AM
NAimportracer's Avatar
NAimportracer
I know exactly what you mean. Your alternatory (not battery) may need to be replaced
Old Jul 6, 2005 | 09:54 AM
Running925's Avatar
Running925
Your Powder Coater
being that it's much easier to test the battery (ie. two 10mm nuts & carry it into the auto shop)
i'd test the battery first & then if it checks out fine.. i'd have a test done to see if while the alternator is under a draw if it's still producing the voltage that it should be.. most likley it's your alternator causing the problem & your battery is struggling to haul you around!
Old Jul 6, 2005 | 11:53 AM
mini-me civic
thanks guys.. imma bring my battery in a shop today to check it out..
Old Jul 6, 2005 | 12:29 PM
foot's Avatar
foot
You can load test the alternator and the battery without removing it from the vehicle.
Old Jul 6, 2005 | 01:01 PM
mini-me civic
how do you do a load test??
Old Jul 6, 2005 | 03:53 PM
mini-me civic
found the problem, i had a burnt fuse, it was the alternator fuse, replaced it and now the speedo works fine and lighTs dont dim.
Old Jul 6, 2005 | 05:43 PM
foot's Avatar
foot
Excellent.
