overheatin but not quite in my hybrid
Old Sep 2, 2002 | 11:04 AM
Outxider's Avatar
Outxider
X-Motoring
Default overheatin but not quite in my hybrid
i got a b16 in my si and my temp be gettin superhot durin hot days. i got a autometer water temp and normally, my gauge be sittin around little under 210 degrees. when the weather gets hotter and im just daily drivin around, my shiet be risin up around 250-270 and up and my stock temp goes half way. my fan and thermostat all works fine.
is it because i still have the puny civic radiator? should i step up to the del sol one? i know my headgasket is fine, i dun see my any leaks and such. im usin prestone coolant, is there a coolant better then prestone?
any ideas?
Old Sep 2, 2002 | 11:44 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
maybe your water pump is on its way out, and the bigger engine/higher temps is pushing it to the limit?
Old Sep 2, 2002 | 12:04 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I didn't think D and B water pumps were compatible...
I know the cooling fan kicks on at 198-202 on a D, but on a B I'm not sure. I'd probably upgrade to a bigger radiator. That or go ghetto style, NO HOOD!!!
Old Sep 2, 2002 | 12:05 PM
Fujiwara Takumi
It's my first day.
how about a box fan cut into the hood?
Old Sep 2, 2002 | 03:00 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
No WAY!!! That fan can be put to good use as an electronic supercharger! :fawk:
Old Sep 3, 2002 | 02:38 PM
ManTiS's Avatar
ManTiS
NinJA
Ghetto it. Rig the fan to a switch and turn it on whenever you feel like it.
Then get a fat PWR radiator (or something similar) for an INtegra, rip out your AC (if you have it), and your worries SHOULD be over.
Old Sep 3, 2002 | 02:50 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
get a Teg radiator!
Old Sep 3, 2002 | 05:04 PM
Nelson's Avatar
Nelson
Administrator
Originally posted by Smurf
get a Teg radiator!
I think I need to upgrade the radiator also...
Would the Teg fit (while keeping the A/C?) I'm a little ***** afraid of the heat :ghey:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 3, 2002 | 06:41 PM
Outxider's Avatar
Outxider
X-Motoring
nah i dun wanna upgrade to a teg one, cuz im plannin to put ac in soon. i was thinkin bout a delsol one would be a nice step up from my civic one. or if i can get some more $$$ get a aftermarket one. basically, my car only gets really hot during long drives like 30+ min worth, in the hot weather. on cold nites and such, the temp is fine. any more ideas?
late
Old Sep 4, 2002 | 06:39 AM
Paul's Avatar
Paul
Eater of Rice
Get a fluidyne radiator
