Brake caliper help
Old Jul 2, 2005 | 10:49 AM
MPerson's Avatar
MPerson
Default Brake caliper help
Just replaced my pads, I tightened everything and then turned the car on to see if the brakes were good. The wheels didn't move (still jacked up) and when I loosened the top caliper bolt, they would spin... is that normal? Should I not tighten them completely since the new pads need more room?
Old Jul 2, 2005 | 10:57 AM
mini-me civic's Avatar
mini-me civic
try takin ur car off the jack and than drive it around to see if the brake calipers release..
Old Jul 2, 2005 | 11:40 AM
MPerson's Avatar
MPerson
Okay, they're fine now, they just needed a little breaking in to get the caliper back to it's normal position.. all good now. Thanks
Old Jul 2, 2005 | 07:56 PM
foot's Avatar
foot
Did you grease the slide pins? Also, make sure the rotor is not cocked, possibly by debris on the hub or back side of the rotor.
Old Jul 2, 2005 | 09:28 PM
MPerson's Avatar
MPerson
You mean the retainers? Yea, i greased them and the brakes pad ears, the squealing is gone now, I just had to leave them tightened and let it settle.
