apex'i turbo timer wires
Old Jun 24, 2005 | 03:11 PM
four's Avatar
four
Default apex'i turbo timer wires
i bought an apex'i turbo timer and i know what some of the wires do
grey = hand brake
white = o2
black = ground
red = constant power
the questions right here :
blue = ig2 = what color wire does this connect too?
green = ig1 = what color does this wire connect too?
thanks
Old Jun 24, 2005 | 03:12 PM
four's Avatar
four
oh and btw, 4dr Lx Civic 1999
Old Jun 24, 2005 | 03:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It really helps if you have a Helms manual or a wiring diagram to show you which ignition wire is energized so you know which wire to hook up. The ignition 1 wire goes to the wire that is energized when the key is in the on position with the engine off. The ignition 2 wire goes to the wire that is energized when the key is in the on position with the engine on.
And I think that the white wire that you said connects to the O2 sensor wire actually connects to the VSS like it did on my Greddy TT.
Old Jun 24, 2005 | 03:24 PM
four's Avatar
four
in the instruction manual it says "(O2 sensor signal (white wire)"
also i dont have the helms or haynes manual where im currently located..although i have it at my house which is clear across town. we have it mostly wired up, and the car is apart..., if anyone has it, can you please look for me
thanks
ps: just the colors of the wires
Old Jun 24, 2005 | 03:51 PM
Provocateur
On permanent hiatus
OK, I guess Apexi and Greddy have different wiring.
On my Integra, the ign 1 wire was black/yellow and ign 2 was yellow. I don't know if it is the same for you but it may help.
Old Jun 24, 2005 | 06:46 PM
four's Avatar
four
we got it
blue wire -> ign1 = black w/ a yellow stripe
green wire -> ign2 = white w/ a black stripe
oh and btw thanks for your help also
Old Jun 24, 2005 | 07:37 PM
Provocateur
On permanent hiatus
Good to hear. At least I was right on 1 out of 2. h:
