Cold Air Intake VS. Short Ram Intake
It helps slow the progression of ambient heat from the engine but once the whole engine bay is heated up (stop light, staging) then it's ineffective.
It sounds like you're just a street driver. Don't race on the street. So a CAI is best for you. Get AEM V1 or fabricate one with a K&N cone filter (just copy an AEM V1 dimensions). Or get a cheap Ebay CAI and toss the filter and get a K&N instead.
keep the racing on the track.
as far as the intake goes...it is not going to get you power to pass up cars.
if a system uses a maf, the objective is to have the maf as close to the throttle body as possible. and the longer the tube u use, (AEM IS BS) . the hotter the air temp when it reaches the TB. I suggest shortest as possible.
Originally Posted by 4Banger69
I know to race on the track, I do. So what intake would be best for track racing?
what kind of track racing?
what other modifications do you have on the motor. an intake alone will do little or nothing?
AEM hybrids as I see has never came out.
Originally Posted by chimchim
If you're thinking the same thing I am, then a hybrid intake is essentially a CAI that comes in two section connected by a silicon connector. If you remove the lower piece and attach the filter to the upper, you effectively convert it to a ram air.
