oil leak inside distributor
Old Jun 5, 2005 | 06:17 AM
bibditty's Avatar
bibditty
Default oil leak inside distributor
Hello,
I have an 89 honda civic that is leaking oil from inside the distributor.
I took off the distributor cap and it is wet with oil.
my question is , is there a seal or o ring or bushing that needs to be replaced?
and if so how complicated is this to do?
I would appreciate any advice or instruction on this matter.
Thank You
Old Jun 5, 2005 | 07:06 AM
twinring's Avatar
twinring
there is an o ring on the outside of the distributor on the rotor shaft, however, if your distrubutor bearing is wearing thin, it will cause lateral movement of the rotor shaft causing the seal to malfunction
Old Jun 5, 2005 | 04:50 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
If the internal seal is gone. You must replace the whole distributor assembly.
