compression help!!!
Old Jun 4, 2005 | 10:55 PM
hondaCRX's Avatar
hondaCRX
Default compression help!!!
whats the right compression for an 85 crx Si? im getting 140, 145, 140, 142
now i look at the haynes manual and all they are showing for compression is the ratio... which is 8.7:1
help please!!!
Old Jun 5, 2005 | 01:12 AM
maestro5050's Avatar
maestro5050
Compression ratio of the engine, and compression of each cylinder are two completely different things. The numbers are consistant which is a very good thing. I don't know what the factory numbers are, but it looks like it should be on the money.
Old Jun 5, 2005 | 11:09 AM
tonysstudio's Avatar
tonysstudio
those are good numbers.
Old Jun 5, 2005 | 02:06 PM
hondaCRX's Avatar
hondaCRX
i just head that the highest is 150 and loswet is 130.. so i guess im good with that.... does anyone know how much power difference im at compared to stock(back in 85)?
Old Jun 5, 2005 | 02:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The numbers are very consistent, so I would say that it is fine.
Old Jun 5, 2005 | 04:57 PM
Kai's Avatar
Kai
Rotorphile.
That's just peachy for an 8.7:1 engine. It should be running not far from how it was originally, assuming you have good injectors, a clean air filter, a clean fuel filter, etc.
