3 inch drop to much?
Old Aug 31, 2002 | 12:55 PM
CivicOnSteeles's Avatar
CivicOnSteeles
Default 3 inch drop to much?
just wondering if a 3 inch drop is too much, and is my oil pan at a risk?
Old Aug 31, 2002 | 01:03 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
yes it will scratch like all i think the max should be 2 inch i dont know about the oil pan thing though
Old Aug 31, 2002 | 04:08 PM
Kevin's Avatar
Kevin
Banned
i notice u have the n1...
itll at least scratch ur exhaust tip like crazy...
happened to me b4..
Old Aug 31, 2002 | 05:44 PM
randomtask77's Avatar
randomtask77
Wanderer
It might look good because you're still rolling on your stock steelies. Once you upgrade to bigger wheels/tires, a 2" drop would be sufficient.
Old Aug 31, 2002 | 06:41 PM
JulioM's Avatar
JulioM
If done properly Shocks,Camber Kit etc.. you should be ok.
if you go 3 " get a camber kit.
to prevent your car from looking like a cartoon car.
also buying tires every 2 month.
lata
Old Aug 31, 2002 | 09:06 PM
CivicOnSteeles
alright, how is my oilpan? should i worry?
Old Aug 31, 2002 | 09:25 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
toe hooks and front chin will scrape before oil pan, there are some plastic and metal bits that catcha lot of grief before the oil pan.
Old Sep 1, 2002 | 12:49 AM
GReddyboy's Avatar
GReddyboy
When I had about 3inch drop on my hb, I barely had any problems, just look out for steep driveways and big speed bumps. I do tend to only scape my front factory lip occasionally when I dont slant the car sideways enough on the driveways. You will only scape the bottom of the car on BIGGGGG speed bumps, just try to avoid those by going around them. However, I have no problems scaping my oil pan or tow hooks or anything. You said you had an N1? I think you going to have a problem scaping that, those hang really low. Roads where I live aren't so bad, if roads where you live at is bad don't go more than 2 1/2!!! Oh yea, I had 13 inch vxs with groundcontrols, with no wheel gap, so yea its around 3 inch drop. Peace
Old Sep 1, 2002 | 07:03 AM
Fujiwara Takumi
It's my first day.
my friend got his camaro caught on a speedbump once and couldnt move. I generally take them at an angle so only one wheel crosses them at a time.
Sure-Oz
Accord
8
Apr 26, 2003 12:17 AM
lilboi
Accord
5
Mar 13, 2003 07:42 AM
