looking at a hatch.
with a gsr swap in it, the dude said it Needs a speed sensor and an idle air control valve, how much would that run me if i were to buy both of those?
Also What does the car do when it needs these parts? Just doing a little homework before i jump into anything! Thanks!
Does it have ABS? If so, is the speed sensor (that needs to be replaced) part of the abs system? If it is, you will get an ABS light, and the ABS system won't work.
Currently my right rear speed sensor is faulty. The part is $100.61 from www.cheapesthondaparts.com.
If it is just regular vehical speed sensor, it goes for 72.83 from the same website.
Originally Posted by FATHONDA
but what if he never had an abs light.?
yo speed sensor, to clairfy and not be el goofo, you will have to buy one for the transmission and change the end to match your harness. if it has an extra wire, you need to run it to the proper pin array.
