F'ed my Clutch Up
Old May 26, 2005 | 09:00 PM
Temporary's Avatar
Temporary
Default F'ed my Clutch Up
So i was driving around tonight, and i was doing 45 mph, and started to slow down. I was gonna downshift, so i pushed the clutch in and pulled the car out of 5th, and all of the sudden i felt a pop in the pedal. I noticed my pedal was not as tight as it normally was, so instantly i thought i no longer was in control of the clutch. I couldn't get the car in any gear since the clutch wasn't disengaging. When i was stopping at a red light, i got my car in first, but, as soon as i came to a stop the car stalled out! I now can't get the car started. At first nothing would happen when i turned the ignition. But i left the car sitting for a few hours and came back, now i can hear the starter whining, but nothing is happening.
Did i kill a master or slave cylinder. Or did i blow the clutch release bearing??
BTW the car is a 99 Civic SI. Thanks in advance!!!!!!
Old May 26, 2005 | 09:49 PM
dohCivic's Avatar
dohCivic
pop the hood and locate the rubber casing on your tranny. thats where u can feel any movement when pressing the clutch in. if u dont feel anything than its probably a cylinder if u do feel some movement then it might be the bearing
Old May 28, 2005 | 02:12 PM
Temporary's Avatar
Temporary
Took my car to a shop. Said the two clutch plates pretty much fused together when my performance clutch fell apart. They said they don't know what happened. I had a factory clutch put in. I hate it! Anyway to tighten this or adjust it, because it catches REALLY high. A bit annoying!
Old May 28, 2005 | 02:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here, see if this helps:
File Type: jpg
