who uses synthetic and who uses regular
Old May 28, 2005 | 08:32 PM
FATHONDA's Avatar
FATHONDA
Default U Know It
all the way. MT too.
Originally Posted by 4Banger69
Mobil 1 10w30
Old May 28, 2005 | 09:09 PM
Wharbone's Avatar
Wharbone
Castrol GTX High Mileage 10w30
Old May 29, 2005 | 01:23 AM
oscar_425's Avatar
oscar_425
Got V-TEC??
Originally Posted by str8edgexx
Mobil 5W30....the Y7 isn't worthy of synthetic :sad:
why??? I was thinking about changing to synthetic... I have a d16y7 too..
Old May 29, 2005 | 01:00 PM
FATHONDA's Avatar
FATHONDA
synthetic is just plain good, everyone has opinions, like seals start leaking, if they do replace them. a rubber is cheaper than a berring to do
Old May 30, 2005 | 10:01 AM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Synthetic blend from Canadian Tire. I used it before in my '91 civic before selling it for a '95 Odyssey with good results.
Old May 30, 2005 | 10:20 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
RedLine Oils 5w30 Synthetic - B16A2.
Old May 31, 2005 | 03:13 PM
FATHONDA's Avatar
FATHONDA
the blend i never understood the theroy behind that except price? am i far off?
Old May 31, 2005 | 07:36 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
Originally Posted by oscar_425
whats the difference between synthetic and regular??
some1 answer this ?....
Old May 31, 2005 | 08:38 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Synthetic oils resist thermal breakdown and losing it's viscosity (how thick the oil tends to stay when heat is added). Plus sythetic oils tend to last longer and don't have to be changed as often as regular oil - so it can save you more money in the long run.
Regular conventional oil tends to break down quicker and loses it's viscosity as more heat is applied. When this happens your engine's internal metal parts can get closer and closer and make contact causing friction and wear.
Autocross Help Page
Old May 31, 2005 | 09:10 PM
Wharbone's Avatar
Wharbone
That's a great explanation.
Q: Why is synthetic not good for high milage engines?
Also, if someone uses synthetic oil twice as long as regular oil, they should still replace their filter every 3,000. Right?
