Trying to figure out what this damn guy did to my 4dr
Old May 25, 2005 | 11:54 AM
JesterMasque's Avatar
JesterMasque
ETERNAL GRINNING ^
Originally Posted by ajamesc
also, the gas guages are always off anyways with Civics....
Yea, but if he put in a gallon there should be no problem. If you did run it bone dry and die to many times I'd say your fuel pump over heated. But if you can't get it started with starting fluid... that's not good. Cause it should at least crank over for half a second.
Old May 26, 2005 | 06:14 AM
twinring's Avatar
twinring
I think your coil and or ignitor went bad during his "test" I had something similar happen to me and it could be that these parts were on thier way out or his unorthodox testing caused a failure, In all my years of working on cars, Ive never heard of such a "technique"
Old May 26, 2005 | 08:29 AM
HondaCivicCRXSi's Avatar
HondaCivicCRXSi
If you car is stick you can push start it, call the guy and beat him down
Old May 26, 2005 | 09:07 AM
wilsel's Avatar
wilsel
You can not push start or roll start a car that has ignition problems, that only works if a dead battery is the problem.
Old May 26, 2005 | 03:04 PM
Temporary's Avatar
Temporary
You can start a car by popping the clutch if your starter is dead as well.
And if you were already almost empty with you tank, and only added a gallon, i have had problems where my car wouldn't start with only that much in it. Is the car on a flat surface?
Old May 26, 2005 | 04:20 PM
Kabooki's Avatar
Kabooki
Yeah, its on a flat surface, Today I tried the screwdriver in the plug wire next to a bolt and tried starting it, I got no sparks that I could see. So i took the dist. cap off and tried to get the rotor off, I unscrewed the rotor and pulled gently and it came off with little effort. Then I realized that the base of the rotor was still on the distributer peg. It was broke in two. So I took the rotor off my 4dr and tried to start it but still no spark. Im pretty sure the coil is out and the rotor is just coincedence as usual.
Old May 26, 2005 | 09:02 PM
Temporary's Avatar
Temporary
Do you hear you fuel pump when you turn the car to accessory?
Old May 26, 2005 | 09:42 PM
dohCivic's Avatar
dohCivic
how was the distributor cap? did u try all the plug wires?
Old May 26, 2005 | 11:19 PM
96Civic_Coupe's Avatar
96Civic_Coupe
Assistant to the manager
Originally Posted by oscar_425
push start that biatch and put some fuel on it... and buy some injector cleaner or seafoam...
what exactly do u do with the seafoam? just dump it in the gas tank and drive around a bit?
Old May 27, 2005 | 03:38 AM
moo's Avatar
moo
he has eaither brnt out the coil pack or fubard the distrubitor, get some one with the same car and use there distrubitor and see if that help, or try the coil pack, you'll find out if it one or the other, if not, then i donno! hope i could help!
