Head back on...engine races!!!!!!!
Old May 23, 2005 | 10:44 PM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by KC_JoNeS
Well, I got the head retightened, and it did help. I found the line to the canister as well....done. Now, the engine revs from 1.5K to 2K RPMs over and over, once it is a little warmed up. Also, the check engine light is blinking continuously. I tried shorting the two lines at the blue connector under the dash on the right, and turned on the key, but the check engine wont blink a code...it just stays on solid. WTF????
mine did that when I had a bat IACV
Old May 24, 2005 | 03:01 PM
KC_JoNeS's Avatar
KC_JoNeS
Well, I found the intake was still leaking.....even after I checked it. I had to replace the intake gasket again.
No sweat. It just got smogged. Thanks to everyone who offered a few words of advice.
Old May 24, 2005 | 06:41 PM
FATHONDA's Avatar
FATHONDA
Default that was my guess :)
i must aggree that and air in the coolant system to boot?
Originally Posted by Shmoo
I had a similar issue and it was because the old intake manifold gasket wasn't fully removed when putting the new one on, so the seal wasn't tight enough, so air just bypassed the throttle body through the leaks.
Old Aug 1, 2005 | 12:44 AM
brettybaby's Avatar
brettybaby
Idle Air Temp Sensor
where is this sensor on a f22a1 motor?
