99 civic SI ecu...
Old May 19, 2005 | 06:09 PM
mini-me civic's Avatar
mini-me civic
Default 99 civic SI ecu...
Im planning to do a B16A2 into my EK.. The swap comes with everything including but i need to know if the SI ecu which is a OBD2 will plug right into my stock wire harness... i know ill have to do some wire mods... but the ecu should plug in directly... right.......????
Old May 19, 2005 | 06:50 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
yes it will plug... does you engine came with vtec?? if id didnt.. you gonna have to add like 4 wires.. one for the knock sensor, another one for the vtec solenoid, and the other two for the vtec oil pressure sensor...
Old May 19, 2005 | 07:42 PM
mini-me civic
nah.. my old motor doesnt come it vtec... how hard will it be to hook up the 4 wires....
Old May 20, 2005 | 09:20 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
use the search function bro.. you will fing everything in there... just put :how to hook vtec wires" or go to google.com .. you will find tons of results
Old May 21, 2005 | 10:59 PM
stereo's Avatar
stereo
if you have a 99-00 then just use the B16a2 engine harness just have to wire up the 2nd O2 if you have a 96-98 then you will need a custom harness as the 99-00 EK has the OBD2b the plugs will fit but wrong pin assignment.
Old May 22, 2005 | 06:22 AM
teg92's Avatar
teg92
WHAT OK YEAH!
:werd: 96-98 is OBD2a and 99-01 is OBD2b so therefore you would need the ECU conversion harness. You dont have the Si wiring harness?
Old May 22, 2005 | 12:47 PM
mini-me civic
my car is a 96 cx...
Old May 22, 2005 | 02:16 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Then its obd2a and you will need a jumper to make it obd2b.
At that point I cant justify using the em1 ecu. Get the jumper and go with a p30. If you can find an ecu from a 96-97 del sol vtec then you'll be set...but good luck with that one.
Old May 23, 2005 | 12:05 AM
stereo's Avatar
stereo
since you have a 96 then you can try to find a jumper harness (rare) or try to repin the ecu plugs (2hours) or use a 96-97 del-sol ecu (plug-n-play) but since I live in california and the car I did the swap had to pass inspection
I repined the ecu plugs .
Old May 23, 2005 | 06:15 AM
PDiggityDogg
What do you mean a jumper harness is rare???
