engine trouble
Old May 11, 2005 | 11:25 PM
honda5's Avatar
honda5
Default engine trouble
engine trouble
Hi all, this is the first time I can get through. So pleae, I just giving a 91 hatchback civic with engine trouble. I did everything except no spark.
thanks!
Old May 11, 2005 | 11:30 PM
so its not starting? i dont get it... you did everything but you dont have spark? do i have this right, sorry im confused
Old May 12, 2005 | 08:53 PM
honda5's Avatar
honda5
Sorry about that, let me start over.
I got the car from a friend. Thinking it is timing problem. I setted the timing least 10 times. The coil and ignitor had been changed. It cranks fine and got fuel, but wont start. I unplug the #1 plug-wire to check for spark and it was none. At this point I am clueless.
Please help.
thanks!
Old May 13, 2005 | 05:48 AM
twinring's Avatar
twinring
how did you check for spark just by unplugging the #1 wire? Did you remove the plug?
Pull off the dist. cap and crank the engine. does the rotor move?
Old May 13, 2005 | 07:42 PM
honda5's Avatar
honda5
I never pull the spark plug, just the plug wire and placed by the block while someone crank the engine. Never remove the dist. or cap. I know the guy before me hook up alot of lights and prob-light and gauge. I dont know if it burn anything. I checked the Haynes repair manual (civic 84 thru 91) and on page 5 - 9 (#12) tell to check fuse #32 (50 Amp) located in the dash fuse box to make sure not blown. I checked and could not locate the fuse itself.
Thanks!
Old Jun 7, 2005 | 10:41 PM
honda5's Avatar
honda5
ahhh finally she starts.
Old Jun 7, 2005 | 10:54 PM
flatliner's Avatar
flatliner
Fix It
she starts! yey, what did you have to do to start it?
Old Jun 8, 2005 | 08:36 PM
honda5's Avatar
honda5
The capasitor (I think that what is called. not the igniter or coil) was bad.
thanks!
Old Jun 9, 2005 | 06:07 PM
flatliner's Avatar
flatliner
Fix It
cool. thats not an everyday failure. bravo.
Old Jun 9, 2005 | 10:24 PM
honda5's Avatar
honda5
It is not very common, the guy before me of prob-light and neon light. I think he burned something in the distr.
thanks
