More CEL's than you can throw a stick at!
5-finger discount :rick:
Originally Posted by syked
what video?
warm butter on toast
It cranks but doesn't start. It seems like a good paced crank, not slow. And when I jump the service connector it flashes. I don't know how to host videos and I don't have cuteftp anymore.
EDIT~The electronics come on and I can hear the fuel line priming.
So, how should I check em? Get new wires and plugs? Also, I have like 1/8th a tank, and the front end is still on jack stands, could fuel not be making it through the line? I doubt it'd not make it, but might as well ask.
1999 Civic Driver
When you turn the key without starting but enough to turn on the blower, etc, do you hear the fuel pump? If not, it may be your main relay. There's a few weblinks on this fix this but I don't have time to find them now.
I don't have a puller or a deep enough socket -_-. Autozone trip: 352023459 comming up in a few minutes.
EDIT~ Does the order of the wires in the dizzy cap matter? Cuz I just plugged the wires in (if your looking at the cap from the front of the car, 1st wire, top rear hole, 2nd wire bottom rear, 3rd wire, top front, 4th wire, bottom front.
