For those of you who have done the washer trick
i use 4 - 1/16in washers in my rear on a 00 civic coupe, works fine, still a lil neg camber tho. If the camber is that bad at 4 washers then jest opt for a rear adj. camber it, It'll save you the guess work
New Zealand
I've been useing 2 washers for 5 years or something with no issues. My last set of rear tires lasted me through 3 sets of front tires. I think i would like a third though, but I remember their not being enough room for three?
my bum is on the swedish!
I used 3 washers on my 2.25" drop, and I have about -1.5* of camber in the back.
as long as you have less than -2.0* camber, you'll be fine. A little negative camber in the back helps in curves h:
bang bang.
18secferio, you got any pics of the rears? im trying to find pics of people rears who know how much degrees their camber is, so i can judge mine. so i can see if i need more/less.
Originally Posted by Hambone
Your car looks sweet with the sideskirts & front/rear lips painted. :thumbup:
too bad its sitting in the shop right now. getting the harness that runs through the driver door replaced, since the wires kept cracking and making contact, causing various things short out :sad:
but the plus side is I'm renting an '05 maxima in the meantime :driving: :grinpimp:
Originally Posted by 89civicSiR
lemme guess enterprise??
but ya mine is pretty low and i only used 2 or 3 and its almost perfect. get new longer bolts tho
i used either 35mm or 40mm, I can't remember which it was. The stock size is 20mm, but the 1/2" washers can add up to some thickness...
