Car won't start.
Old Apr 27, 2005 | 06:07 PM
Wharbone's Avatar
Wharbone
Default Car won't start.
Ok, my car wouldn't start today before I was to leave for work.
I had just driven it about 2 hours prior to this happening.
When I put the key in, and turn it (not cranking engine) the check engine light comes on, and goes out like normal. I can also hear the fuel pump prime itself. When I crank the engine it turns, but never turns over.
Because of this, I imagine it is probably a spark problem. (I just got home from work and havn't had a chance to check for spark yet.)
I think it is probably the coil or ignitor unit. I will test those, and look at the plugs, cap and rotor.
I just did a tune up about a year ago, so I doubt it is the cap, rotor, plugs, or wires.
What else should I look for? Thanks in advance.
Old Apr 27, 2005 | 06:18 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Starter maybe? Prolly, not the starter. But I always check EVERY possibility.
Old Apr 27, 2005 | 07:38 PM
Wharbone's Avatar
Wharbone
bump, any more suggestions?
Old Apr 27, 2005 | 08:17 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
sounds uber simple...
but check grounds
it always ends up being the most simple things for me.
Old Apr 27, 2005 | 08:22 PM
Wharbone's Avatar
Wharbone
but check grounds
Alright. Do I just look for corrosion on them?
Old Apr 27, 2005 | 08:30 PM
Wharbone's Avatar
Wharbone
also, does the fact that my car cranks without turning over rule out either the ignition coil or ignitor unit? Sorry, I don't know much about this.
Old Apr 27, 2005 | 09:07 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
No, actually it emphasizes that it could be ignition.
Also are you sure your fuelpump is doing its job?
I am betting ignition.
Yes, check for hardcore corrosion. It all depends on where you live and what kinda climate
Old Apr 28, 2005 | 10:09 AM
98GRNCVC's Avatar
98GRNCVC
I HAD THE SAME PROBLEM WITH MY ACCORD, CHECK THE MAIN FUEL RELAY WHICH WOULD BE UNDER THE DASH BEHIND THE STEERING WHEEL. I REPLACED MINE AND IT DID THE JOB
Old Apr 28, 2005 | 11:03 AM
HcOiNvDiAc's Avatar
HcOiNvDiAc
GOT HONDA?
check your battery cablels, make sure ther snug
Old Apr 28, 2005 | 11:09 AM
RsxSpeed's Avatar
RsxSpeed
SupaCharga!
this is gonna be a pain in the ass for you to fix/figure out without the proper tools/gauges...
it could be alot of things such as ignition, battery, fuel, starter system in general... i luv cars but damn, its so hard to narrow problems down sometimes
