Found new oil leak
Old Apr 18, 2005 | 07:37 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Default Found new oil leak
The new leak seems to come from what looks like the oil pressure sending unit right below the distributor assembly. Can I just remove and put something on the threads to keep from leaking or must I buy a new one? Some liquid gasket should seal it up pretty good I think.
Old Apr 18, 2005 | 09:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would try cleaning off the threads and then wrapping them with teflon tape. If that doesn't solve the problem, buy a new one. They are probably insanely expensive, so start with the cheap solution first.
Old Apr 19, 2005 | 11:37 AM
dpkelly's Avatar
dpkelly
1999 Civic Driver
I have the wrong sensor. It is not the oil pressure sending unit. There is some kind of sensor screwed into the block directly below the distributor assembly that's leaking oil. Does anyone know what this is? The oil pressure sending unit is near the oil filter.
The gasket thats attached to the distributor assembly could also be leaking. Any pointers?
Old Apr 19, 2005 | 11:44 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Which motor? Do you have pictures?
Old Apr 19, 2005 | 12:05 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Good ole D15B7. 1992 civic DX. This sensor right under the distributor and inserted into the block just above the tranny.
Old Apr 19, 2005 | 12:19 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
If you can screw it out then put teflon tape on it as Shmoo said. I wouldn't ever use gasket sealer on a sensor that screws into an open orafice where the pieces could float around in the motor.
Old Apr 19, 2005 | 12:30 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Would teflon tape handle the temperatures? It might also break down to small pieces.
Old Apr 19, 2005 | 12:34 PM
westcoaststyle
I use teflon tape on my turbo oil feed connection. You decide.
Old Apr 19, 2005 | 12:48 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Duh, I should know this. Teflon (aka PTFE) can withstand high temperatures (a few hundred degrees). Thanks for the tip.
Old Apr 19, 2005 | 02:47 PM
Provocateur
On permanent hiatus
Same here. h:
