99 Ls in ek?
Old Apr 17, 2005 | 09:28 AM
LsEk's Avatar
LsEk
Default 99 Ls in ek?
I have a 97 hatch and want to put a 99 ls motor. I need help with the engine wiring. If anyone has any info, I will appreciate it.
Old Apr 18, 2005 | 06:11 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
www.google.com
Old Apr 18, 2005 | 06:16 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i did the same swap in my car. There is some wiring you have to change around. Heres a link that tells you exactly what you have to do.
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
that will give you all the wiring info that you will need to get the car running perfect
Old Apr 18, 2005 | 07:46 AM
LsEk's Avatar
LsEk
Thanks for the info, http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg, I really cant see it good, words are too small. Any way i can get bigger?
Old Apr 18, 2005 | 08:07 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i can see mine perfectly fine
Old Apr 18, 2005 | 09:14 AM
LsEk's Avatar
LsEk
Im doing an ls. It has no vtec. Im also using a obd2a p75 ecu.
Old Apr 18, 2005 | 09:17 AM
LsEk's Avatar
LsEk
Do you know how many 02 sensors do the integras have?
Old Apr 18, 2005 | 09:34 AM
thomas's Avatar
thomas
pew pew pew
if its a 99 ls motor it will be obd2 and have 2 O2 sensors
Old Apr 18, 2005 | 08:03 PM
LsEk's Avatar
LsEk
The motor is 99 but the ecu is 97. By any chance, do you have an extra engine harness?
Old Apr 18, 2005 | 09:48 PM
thomas's Avatar
thomas
pew pew pew
hey check here https://www.honda-acura.net/forums/m...oster&t=184886
