look at em
I got a ls/vtec in the builds, here is most of my parts and a parts list
Pic now added:
B16 head
reguided and sealed by oe gaskets
buddy club specIII+ cams
omni valvesprings and retainers
three angle valve job
cam gears of choice
oe head gasket
AEBS intake mani
act hdss
exedy 9lb fly
toda 12.5:1 pistons
eagle h-beams
arp rod studs
clevite rod bearings
federal thrust and mains
oe main bolts
b18 block
oe vtec water and oil pumps
oe t belt
gs-r windage, pan and pickup
z10 girdle
p28 hondata tuned ecu with datalogging
550 rc's and walbro 255
dc 4-1 with 2 1/4" collector
magnaflow cat and res
tanabe muffler
Nothing too special, hope it runs
well i will get pics up later
Pic now added:
B16 head
cam gears of choice
oe head gasket
AEBS intake mani
act hdss
exedy 9lb fly
toda 12.5:1 pistons
eagle h-beams
arp rod studs
oe main bolts
b18 block
oe t belt
z10 girdle
tanabe muffler
well nows the best time, if you wanna a perfect b-series block, i can give you a connection for one. Bare block with a new crank, LS block btw. Do EEEIIIIIIIIITTTTTTT mang.
thanks for all of the replys, i have 9.5:1 srp's right now, this motor was meant for turbo that i am running right now, but i hve figured it out, I am too damn broke for a turbo. I will never do it. Anyhow about the heads, the b16 suposedly flows a little better, but has a little bigger cc in the actual head, which works great for me cause i am runnin a piston with a dome of 8.9 cc. Anyhow, the picture i have is too big supposedly so imma have to link it through wetoddid.
